Originally posted by suprra_girl@Jul 23 2005, 08:11 AM
you say the numbers are high.... that would suggest the opposite actually
you would be running lean
rich would be low numbers
what was the exact a/f ratio?
also your mk3 is a GA70 89 supra ma40 is the mk1 celica i believe heh
Hey thanks for your info and repy
Yeah soz there its way to ritch i mis read the dyno how the scales are set. The dyno says it went too low off the scale im not sure of the number. i might have to scan the sheet and post that. One other thing i noticed is that at peak power the boost dropped off to a flat curv at 10psi. I will be trying a boost leak test and then i will know if its the ecu. Hopefully we can sort this out cos i dunno if the 145 mark is all the car has or if it has more in her!
Cheers
Frank (azzurro)
Cheers
Azzurro
1989 MK III 1G SUPRA
HKS Intake, HKS Exhuast, HKS SS BOV, Custom FMIC, Front Pipe, Reco Turbos, 19" Zanetties, 45mm Lowered Coils,
Dyno 156rwkw @ 10-14psi, Stock internals and EcU
Also NEW MA70 car yet to discover wat its on about
