Originally Posted by SideWinderGX
While this would technically work, the supra meters *all* the air that enters the engine. When air is released when you shift and vented to the atmosphere, the engine thinks its still in the engine...which will cause it to run very rich. the car will still run, but not as well.
then would you have to buy a computer to tune the air/fuel mixture or is the vented air so small it doesn't matter? what have other people done that added after market blow off valves? thanks
White 1989 5sp Turbo Targa
shimmy wastegate 3 washers, 3" exhaust 2 1/2" piping, raised hood 24mm, R1 diamond drilled/slotted rotors
Momo short shifter, White Glow Gauges
Panasonic CQ-C7105U MP3/CD deck, 2x12" Rockford Fosgate HE2 subs, Pioneer GM-X922 amp
