If the coil and ignitor is good, and is the RIGHT setup for the car, you need to check ALL YOUR GROUNDS. One bad ground, especially the one under the intake manifold, can cause a no spark issues.
And yes, check all your relays and fuses, even the ones inside the car in the drivers side kickpanel.
