Well first thing is where did you get the switch and the steering wheel cover from. Is the the steering wheel face from your old one or the new one. The reason I ask this is because if the switch is from japan I know from my clip that not all of the cars over there had cruise. So mine isn't hooked up because I don't really use it anyways.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
