need help!
ok so i rebuilt my turbo and screwed up the balance. i plan to have it re-balanced at the gpop shop in AZ but for now i bought a used stock turbo to use. got the turbo, inspected it, cleaned it up, and everything looked good.
turns out the turbo i had on originally wasn't stock, so i replaced an upgraded turbo with a stock turbo. now i am in a slightly more af a rush to send off mine to be re-balanced but I need transportation in the mean time so i left the stock turbo on the car.
the problem is it idles good, high but good. when i step on the gas all power drops out. if I hold the gas down slightly then it lopes pretty bad.
any ideas?
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
