upgrade advice
a quick rundown - new TPS, power steering pump, Spark plugs, belts, oil change, vacuum lines, upgraded BOV, upgraded IC piping, SAFC2, and 3" Exhaust. Cleaned TB, ICV, and intercooler. Replaced valve cover gasket and the 4 o-rings above the spark plug well.
I am putting an upgraded turbo and a lexus AFM on it next. Is there anything I need to do at the same time?
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
