Call your local junkyards and salvage yards, they may have a Supra there, but you may run into the same problem, the up side is that they will remove the gas tank before putting the car out for pickins. If you cant find one, I may be able to see what the local yards have, I know last week I saw a 89 with the tank in the hatch.
Other than that you can look into buying a aftermarket fuel tank, the squarish aluminum ones.
Good luck.
"Stuck in the 80's"
