Old 07-05-2008, 03:52 PM   #2
robertsws
robertsws's Avatar
robertsws is on a distinguished road
did you pull the codes?
is there any smoke? if there is, what color?
is there any oil under the car?
did you use premium gas?
what's the milage on your supra? how long have you had it? what work have you done to it so far?
when you step on the gas does your oil pressure increase?
is there oil in your intercooler?
is there coolant in your overflow?
these all need to be answered.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
