Old 07-06-2008, 01:20 PM   #13
robertsws
robertsws's Avatar
robertsws is on a distinguished road
i stand corrected, thanks, however you mentioned that i was only partially right on the dipstick info. could you elaborate? on my 87 non-turbo when i stepped on the gas my dipstick would shoot out 2 inches and it was the piston rings and i had to do a re-build. as far as oil pressure rise when you step on the gas. i have the normal rise on my 91 turbo now with just normal operation. on my 87 non-turbo it was riduculous. my pressure would peg out. that is the differance i was talking about.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
