Thread: CT26 for sale!
Old 07-08-2008, 03:06 PM   #6
robertsws
robertsws's Avatar
robertsws is on a distinguished road
here are the pics finally, if you look closely you can see the white marks on the compressor wheel and nut used for alignment. i didn't want to take the housing off but if i did then you could see the additional marks used for alignment. as i said earlier it pulls strong the only reason i'm getting ird of it is that i have an upgraded rebuilt turbo i'm getting rebalanced.
ID:	1563   Click image for larger version
ID:	1564   Click image for larger version
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
