Originally Posted by Busted Knuckles
Sidewinder, you can survive for a bit if you switch to 20W/50 oil, and use a bottle of STP with every change. This bumped my idle pressure to 10-15 psi, and has been holding there for a year. I'm planning on an engine rebuild. It will probably happen this winter or next spring.
Please dont do this.... Putting thicker oil in your car is not the answer....
please read the oil link in my signature Busted Knuckles before you advise someone else....
