Well got it back from Toyota, they said that the valve cover gasket was screwed and that was doing it. There is no way in hell that that could be just it, yes I know its screwed and its leaking some oil, but not that much and it certainly wouldn't make it burn the oil.
At this point I figure it's likely the valve seals.
So I take it that you're saying lighter weight oils are better for engines in their prime but heavier oils are better for higher mileage engines?
