it is blown period
power and all that is normal if the outside temp was lower and you kept adding radiator fluid you could go for miles on a mildly blown gasket ..this gasket is a goner .. just the steam and leaking fluid alone tells me that plus add in the miss firing and that tells me it's not only leaking out but leaking in coolant and missing firing .
IBM says " you make the call "
