Problem solved, thanks for your help. As usual, it was something really simple. I replaced the clamp on the negative battery cable with a cheap one from walmart, and replaced the 8 gauge cable with a 4 gauge cable. I also replaced one wire leading to the CPS. The car started on the first try and hasn't given me any problems since.
Thanks a lot for the help.
