codes 42 and 52
I just checked today and I got codes 42 and 52. One says vehicle speed, and the other knock sensor. What does the knock sensor look like If it is a wire with a big round rubber shield hook to it, I plugged it back in it was lose near the oil filter. If this is the right one do I need to pull the battery cables off and check it again? And for the vehicle speed sensor will a bad speedometer cable cause it to read like this? I know the speed sensors are for the ABS I just wanted to know if it has any connection. If any one has any clue please respond I need all the help I can get.
