ARP studs/bolts are made in the US, I think your find they are imperial (inch) use a 9/16 long reach socket with a 3/8 drive, if your torque wrench is 1/2 use an adaptor. Thread size is 12 mm x 1.25 just in case you need to clean out the holes in the bock, which I recommend you do.
