I might have found the problem
I did the injector cleaner and carb cleaner in the intake, but it was still messing up so I started to pull the wires and plugs to take a look at them, see if the plugs revealed anything.
Everthing checked out till I got to the last two plugs. The spark plug wells where half filled with oil???? My valve cover gaskets are leaking AGAIN.
I replaced them about 8 months ago and stopped the leak. When they leaked last time it didnt cause my car to mess up, but I knew it would eventually so I replaced them and checked it every week for about 2 months with no signs of a leak. Im sure the day after the last time I checked it, it started leaking again. lol I hope this is it.
Oh and I had one other Q. When you adj the tps, do you set it based on how the engine runs or on ohm resistance. thanks
