the stock bottom end ive heard will hold up to 900 hp if in good conidtion the bottom end is all forged internals. very strong the only thing is the tranny wont hold as much and the engine can so ull have to beef it up. second the hg on 7m's kinda suck u can run 16 max psi on the stock hg but u might blow it eventually but no worrys i have a 7m and im boosting 11 and i havent had a problem except a oil leak coming from where the distributor was from the previous models. and to make the boost go up the wastegate is connected by two bolts undo the bolts and put washers behind it i have 5 washers on each side and im boosting 10 to 11.
89 Supra Boosted 11psi
lexus afm
k&n air system
aeromotive fuel pressure regulator
walboro fuel pump
stage 3 weitght reduction
koki style tail lights
silver and black 2 tone paint
Enkei rs7 17" 17.5lbs each
hankook ventus hr2's 225/45/17
apc hood pins
yellow fogs
Soon To be
Megan racing seats, roll bar, either takata or sparco harnesses
