hey thanks well i managed to get my reverse lights hooked up easily using that article but im having problems with the neutral switch it says there is a plug for the clutch sensor underneath dash but i cant find it but i did manage to join 2 wires together from the transmission and it shows neutral on the auto park reverse etc dash lights but does it neccessarily mean it thinks its in neutral? because it still wont start. im just using my auto dash cluster for the mean time any help is appreciated also is the neutral switch for and auto just some wire to the trans or is it a box.
cheers
Originally Posted by pwpanas
The only tech article I'm aware of is a manual (6spd) conversion for a tt. Hopefully it has some info that can help you:
MKIV.COM
When you're done, hopefully you can post some of the stuff that you learn!
