So I am doing a 1986.5 7mge swap into a 87 Turbo Shell and I got everything all installed and ready to start and the car cranks but will not start.
Things I have checked and/or tried per TSRM:
1. Checked for spark (+)
2. Checked timing (+ everything was aligned properly)
3. Checked fuel pressure in rail (+)
4. Checked spark plug (- plug was dry as a bone!)
5. Checked the fuses (+)
6. Inspected relays but did not test (+ could be problem but were working fine when 7mgte was taken out)
7. Checked for voltage at ecu for the injector wires (+)
What else could be the cause of my injectors not firing? Is it possible that all 6 could be clogged as the car doesn't even sputter? Please help, I need to get this car on the road!
Thanks in advance!
