thanks for the response. Here is what I keep reading about adding an extra quart...(supramania)
"Best thing you can do is run a minimum of 6 quarts of good oil in your 7MGTE all the time. (It is not over full at that point, there is plenty of room between your crank and the oil level, but you do have one "extra" quart in reserve to keep oil over the pickup point.)
Most rod bearing failures are on cars running 5 quarts or less of oil. (Leaks are the #1 way to rod bearing failure. You run low on oil, and spin a bearing.)"
"14. Keep oil levels filled as mentioned by Drjonzes, add an extra quart!"
Well my fog lights turn on when I have my parking lights on, but they turn off when i turn on my headlights. Is this normal? As for oil, should i use 10w-30? 5w-30? 10-40?
About TEMS, what is the third light on the dash for? (one light for normal, second one for sport)
thanks again
