Originally Posted by Daithan
Anyone know where the fuse for the A/C is located? Can't seem to find it anywhere in the owners manual.
Thanks.
Its located in the right kick panel, its a 10A. The only other fuse there should be for the blower motor, 30A.
Make sure when you go to pull the panel off you take the door sill out first, then the 10mm nut at the rear of the panel.
Good luck.
"Stuck in the 80's"
