Yes, check the search for a while, there is some good info in thar.
If you are serious about doing this, I may suggest you buy a whole front clip, that way you have all the stuff you need. Buying a front clip will cost more but may save you many headaches in the future.
I may also suggest you check
Driftmotion Garage >> Welcome, they have done a lot of JZ work in MKIII Supras.
"Stuck in the 80's"
