Check over your coil packs, and the CPS, you may not be getting spark.
If there is any doubt about your fuel, find the feed line and put in a bottle and jump the correct wires in the Diagnostics port to see if you do indeed have ample fuel. You can find this info in the TSRM, I'm not sure on what page or I would link it.
Good luck.
Also, have you checked for codes?
"Stuck in the 80's"
