Old 08-18-2008, 05:59 AM   #10
CyFi6
So to be sure, you bolted the shifter into the transmission properly and you can move it side to side, but not to the left and up, to the left and down, up, down, to the right and up, or to the right and down? If you bought it from Toyota im sure they tested it before they sold it to you... Again, did you try turning the input or output shaft as you shifted it? and when you turn the input shaft, does the output shaft turn also? If so, can you hold the output shaft from turning while you turn the input shaft?
