Thanx everyone I found the problem. I set fuel pressure with the vacum line hooked up and that caused fuel pressure for sky rocket under boost ( 80psi). Fuel pressure holds right at 45psi under boost. Now I have enough fuel to feed the fire, at least untill I get a HKS FCD. 15 psi here I come.
P.S. the car is getting really quick. 265hp @ 9psi & 260 torque. Not bad for a lightly BPUed MKIII.
