ok thanks for the info. I guess I will probably look at replacing it in 10k miles or so, since I wont really want to be pushing my luck with a 112k mile car with hopefully some bolt ons. also, did this car come standard with abs?
oh and another thing, whats the final drive ratio? I looked around and saw maybe 3.7, but doing 70mph in 5th i was turning around 3k rpm, little over maybe, and according to this calculator,
Gear Ratio Speed Calculator, 5th with 3k rpm would only be 59mph (I put in 17.9685" for tire diameter since 16" wheel and 50mm tire height, correct? and 5th gear ratio of 0.783)
