I think the latch is for the seat belts, so they wind back up when the door is opened, the one on my car never worked, it was broken. I even replaced it and it broke again, so I find my self guiding the seat belt back up every time I leave my car.
You have a nice car there, rust and dents in all. If you plan to pull the door louvers you will have to pull some of the interior panels off to get the bolts holding them on, as for the rust in the rear, check under your spare tire as well, for now just get some WD-40 and hose every metal surface down in the rear, and in the valleys on the outside of the hatch weather stripping on the car side.
Good luck.
"Stuck in the 80's"
