There you go, I’m in the process of replacing the head gasket at the moment so the battery is disconnected hence no illumination for the dash.
The gauges below the heater controls are non standard, Vac/Boost and Air/Fuel gauges. The rest is a standard 7M-GTE 1990 UK Turbo Supra.
As its night time in the UK at the moment the camera is in flash mode, the red on the steering wheel is just a refection coming up from a red sheet/rag I'm using to protect the drivers seat whist I'm doing my BHG repair.
