Originally Posted by Chambers
I think the latch is for the seat belts, so they wind back up when the door is opened, the one on my car never worked, it was broken. I even replaced it and it broke again, so I find my self guiding the seat belt back up every time I leave my car.
You have a nice car there, rust and dents in all. If you plan to pull the door louvers you will have to pull some of the interior panels off to get the bolts holding them on, as for the rust in the rear, check under your spare tire as well, for now just get some WD-40 and hose every metal surface down in the rear, and in the valleys on the outside of the hatch weather stripping on the car side.
Good luck.
Yeah, I think you may be right about the latch being for the seat belts. It gets pushed sideways everytime the door closes. Probably just releases the seat belt lock.
Found no rust anywhere except that one wheelwell (other is perfectly fine) and the one small spot on the front of the driver's side fender. Hoping that the paint can get matched relatively close once that is repaired.
Really wound this baby out this afternoon... it sure can move... but afterwards I got that smell of burning oil. I got some repairs to do on this motor without a doubt, so I think its probably smart to start purchasing all the parts I will need before I start replacing them (do it all in one shot). I am definitely doing a turbo timer, and will probably mod that downpipe (still dont totally understand what's what under the hood, but I'll get it all down pat soon... ). Now I sit and ponder... did they just throw a 5th gear in this puppy just for those that want to attempt 200 MPH? lol. Im having trouble keeping it at 100kph (60 MPH) in 5th...
