One place worth checking apart from any obvious leaks from the rubber hoses, are the rubber rack boots, give them a squeezing to see if any fluid comes out, this would indicate a rack oil seal worn. The rack boots are at the end of the steering rack (both sides) where the track rod ends stick out. Black concertina rubber tube about 6 inch long.
