Is your radiator inlet in good shape? Is it metal/bent or plastic/broken? There should be a lip on the end of the inlet that makes it seal better and holds it on better. Your hose should not be slideing off, it sounds like your hose is stretched out. Go get yourself a new hose, make sure its the correct diameter and not too big. When you put it on make sure the inside of the hose and the outside of the radiator inlet is dry and clean. I just put a new one on my car and it fit so snug i could probably run it without any clamp and it wouldnt leak. Make sure you use the regular toyota clamps when you put the new hose on.
