Eesh. Don't stick to any one company, number one. MHG is definitely the way to do (metal head gasket). Do head studs (again, don't cheap on quality because your lazy), they will hold much better.[/quote]
Agreed. Studs are much better. And no you don't have to stick to any one company a MHG is just the way to go. I've learned the hard way on a rushing a project and cheaping out. The second time around I took my time and money and did it right. I would highly suggest doing that the first time as it will save you MORE money in the long run
When life passes you by, DOWNSHIFT!
3 inch exhaust, cometic head gasket, arp studs, lexus afm, 550's, custom front fed intake manifold, FM intercooler, daily driven at 12 lbs.]
