Old 09-06-2008, 11:35 AM   #2
Chambers
Chambers's Avatar
There is some info from you that is needed before anyone can give you a good price estimate for a 1JZ swap.
First, what year is your car?
Second, would you be rebuilding, installing the engine, and doing the wiring?
Anyway, here is a link to a post http://www.toyota-supra.info/forums/...e-1jz-2jz.html
There is some info there, as for price you are looking anywhere between 1.5k to 5k, depending how much you do yourself and if you buy a front clip which is the smartest way.
Good luck.
"Stuck in the 80's"
