Possible suspect in Turbo lag and vacuum problems
Alright, I have gone through most of the vacuum lines and haven't seen any that need replacing. Although I did stumble upon this little issue.
(image no longer available)
Im fairly new to turbos in general, could this be the problem that is causing the lack of boost? My other concern is if the turbine and wheel are in ok condition, seeing as how they can suck up some nasty stuff with the hole like that.
Thanks,
-Ryan
