Originally Posted by tak2099
OK, so I just finished with my knock sensor rewire. Went to put my battery back in. I connected the negative, then when I put on the positive, something near the passenger side TEMS actuator buzzes and the temp gauge is spiked up, and the battery and check engine light are on(and the key isnt in the ignition.)
Sounds like a ground issue. Make sure your wiring job isn't exposed and touching anywhere. Did you run a whole new wire from ecu to knock sensor?
![](http://www.toyota-supra.info/forums/image.php?u=16523&type=sigpic&dateline=1221274488) When life passes you by, DOWNSHIFT!
3 inch exhaust, cometic head gasket, arp studs, lexus afm, 550's, custom front fed intake manifold, FM intercooler, daily driven at 12 lbs.]
