I doubt you paid as much as i did... ; ) (6k)
After owning mine for almost a month now, I realise I overpaid by about 2k. Which is no biggie... it's the only way he would part with it.
I just bought a JVC-KDAVX11 DVD deck for it, gonna pull the Panasonic deck out and sell it. This one will read DVD's so I can put my entire music collection on one disc.
Now I gotta rip apart the dash a bit to get at the deck and hopefully wire it all up correctly. So far, I can only see 2 screws in the ashtray, but Im gonna assume there are probably 2-4 more I havent found yet. I gotta ground it to the ebrake as well because this puppy has true LCD so you can watch movies on its mini screen if ones so inclined...
record those youtube drifting movies and play em while you drive.. lol.
If you are talking about the carpet stain, its probably dirt.. but also I wouldnt doubt its brake fluid from a "once leaky" clutch master cylinder. Failing that.. its just heavily ground in dirt... I cleaned mine as much as possible then threw pretty car mats on top of it. Otherwise you just end up grinding a hole thru the carpet anyway.
