Old 09-16-2008, 01:28 PM   #2
shiftysupra
shiftysupra's Avatar
shiftysupra is on a distinguished road
yes 2.5 quarts is right for the w58. you should also change the differential as well. uses the same gear oil unless you have an LSD type you can get the addative to add to the gear oil. Yes you can do it throught the shift boot hole. I too had to get new bolt that you can get at home depot. hex bolts are what i got.
shiftysupra is offline   Reply With Quote
