does your check engine light come on before it completelty shuts off,if so allow the the light to come on ,now the computer can read a trouble code telling you what the problem(s) is.all you need is the obd1 or obd2 code reader to (whichever it is) tell you the code of the misbehaving part(s),this code reader aught to be available at a local parts store.if the check engine light does not come on when the car dies with the tps sensor plugged in,then ,well i'd really have no idea of what the problem is.my last thought is that the tps is not functioning correctly, it may be sending a signal to the computer that is false;telling the computer that there is a very high fuel demand that exceeds the fuel cut limmitations,hence fuel cut off.just a theory.anyhow i hope this helps,laters!
