try putting a 180 degree or 192 degree thermostat in,it's cheep and easy and worth a try.i'll bet at this rate that your thermostat set up is your problem,it will tops cost you 16.00 dollars and at most an hour of labor.without the thermostat the rad does not have time to cool the water .after all an easy fix is the best ,if it is possible.see if it's possible ,laters!
