Thread: Overheating
Old 07-31-2005, 09:00 AM   #11
rnoswal
rnoswal's Avatar
Well, I got the thermostat and drove it around a bit last night. I almost thought it was cured but it started tooverheat again during the drive.
The fan has a shroud, but doesn't cover the whole radiator. I need that row of two fans that is supposed to come with the radiator originally. It is getting too warm where there is now air flow. I think I will try making a lower cover to close th underside off and force the air to go through as much of the radiator as possible.
I do not think it is the head gasket. I just rebuilt the engine and like I said before, I feel confidant in that area. Now I may try to bump up the torque number like I saw "Supra Girl" (supra girl music here).....lol. But it torqued down evenly.
Like I said before, I don't like the impeller setup on the water pump though and thinking that it may be causing some of the bubbling in that area. I did notice a difference between makes of water pumps though. Some had deep blades while a few others were shallow. I suppose I should break down and buy the proper TOYOTA pump, $95.00 ouch!
Keep up the suggestions as they are what is keeping me motivated to continue with this......................thing.
Thanks
Russ
