There should be a screw in the bottom of the coin compartment in front of the mirror controls. There are also two screws at the bottom back of the center console. Remove those three screw and the console lifts out. This is after you have removed the insert covering the shifter and AC controls. Once the console is removed, just unplug the electric lines running to the mirror controls. Just did this last night to clean mine up. It was sooooo nasty the square control would not even rock!!!!!
