All you did was head gasket ?
Pull plugs pour some transmission fluid in each cly... crank motor over let it coat the cly walls... You might have dry cly...
also a hose with a small cut will sound like a bird chirping... acts like a musical instrument reed
also pull all the belts off... and run...
Pin point the noise...
p/s: also a transmission funnle... them long ones.. stick the small end in ear :} makes good listning device
