I very carefully pulled the bottom off of the switch and promptly screwed everything up. When you take the bottom off of the switch do it upside down. There is a metal plate that I have no idea how it goes back into the switch. Once the bottom is off and the insides taken out, the rocker square pops out. I then just used soap and water and a soft toothbrush. There are four prongs that stick out on the bottom piece that you need to pry out. I was able to get three pried out and then worked the bottom piece out. The circut board, which is the bottom piece, I cleaned with windex and q-tips. If you get it apart and see how the metal piece fits in, let me know. I have one more switch, but I haven't pulled it apart yet.
