Thanks that was more helpful, I just took off the timing cover to make sure the cam gears haven't jumped a tooth. everthing checked out and I started it and ran ok. The fuel pressure is to high right now to crack the line, ima let it bleed off some pressure. Then ill put the guage back on to check and get a fuel curve of all conditions and see what I find. As far as a wide band goes, do they make a wideband sensor that will bolt inplace of the old sensor to run a guage and send feedback to the ecm. If so can you tell me where I could buy one. I have ngk wires on right now. I have to wait till next paycheck to get ngk plugs. Im also going to put on a new intake. I think the old ones fine, but it is old and has some stress cracks in it and might be letting un-metered air in the engine. Thanks again, I know im really close to find out whats wrong with her.
Supra Engine Powered Dragster
