going to need a little more info then that, like the years a good start, also im not sure if my scaner even hooks up to the Supra or you have to ground pines in the dignostic port, but there is a port on the front just after the battery, it could be somethng as simple as on O2 or as bad as an intake leak, some newer modlues will have more sensors in them to figure out whats going on, i would say take it to a shop and have a mechanic scan the car and tell you the code, sometimes you can but those cheap code readers at the cheapo auto store, those sometimes work but are mostly not wouth the money.
mind you my snap-on motus scaner id worth.............like 10,000..........im glad my shop picks up those bills.
