I just installed one recently, more than once actually. It should be fine, the hose sort of curves off towards the drivers side slightly and then back across the car. It shouldn't have any issues with clearing anything, not sure what metal plate you are speaking of. Also, even with the metal tab there you can still rotate it a fair amount if i remember correctly.
