TSRM is a great place to start. Without slogging through 300 or so pages here is some quick help.
Originally Posted by supramanpkc
1. there is a slight crack in the radiator on the top, slow leak ONLY when the car has been run and when shut off, it starts a slow leak. how do i fix that?
Best way to fix this is get a new radiator. You can take the radiator out and have it repaired at a radiator shop if you need to save some money. Knowing though, that the blown headgasket problem is most likely related to inadequate cooling a new and larger radiator would be the best route
2. the trim on the car is fading, and some is coming off, and some is off, need that fixed, how?
Either get new trim from Toyota if still available or start looking for a good parts car at local junkyards. The TSRM will have how to remove this stuff so as to save what you can.
3. the trunk opener lever by the driver side is not working, i have to open the trunk manually, how can i fix that?
This is caused by the release cable being stretched over it's lifetime. You can either get a new one or re-route the old one as to lengthen the stretch so that it works properly.
5. the driver side door locker is not working, when you press it, it has no pressure at all, just wont work, the passenger side works properly, how do i fix the driver side problem?
Is this the actual little flipper deally thingie on the door or the power switch in the door handle. If it is the power lock button then either remove it and see if a good cleaning will fix it or get a new one. If it is the manual lever that is not working then you will need to take the door panel off to figure out why. Again, check the TSRM as to how to remove the door panel without damaging it.
6. the ac is not working, the blower works, but there is no coolness, how can i fix that?
Recharge kit. You may need to check a leak check kit. The AC does not work most likely due to a low level of freon. First and most simple check would be to make sure that the AC clutch is engaging when the AC is turned on. Just pop the hood and find the AC compressor. The clutch is on the front of the compressor. Have some one sit in the car and with it running turn on the AC. Does the compressor clutch kick on? If not... get ready to shell out some bucks. If it does kick on, then a recharge is most likely the needed fix.
Again, start with the TSRM. Read it front to back several times before you start working on the car. Then read it a couple of times while you are out with the car. That way you can familiarize yourself with the components of the car and will know what the TSRM is referring to when it tells you something like...
"Check that the ICSV is clear and operating properly"
or "Remove the coolant temp sensor relay..."
I printed out the TSRM so I could sit in the car and do just that.
