ALSO!! I found an exhaust leak.. coming from one of the gaskets between the exhaust manifold and the downpipe.. Could that cause this problem?? The mechanic who did my compression test said it was fine.. I just remember the numbers being weird. It was only cranked for 2 seconds on each cylinder. I didn't think that would give u an accurate reading. And the block test came out clean. All i know is that this problem is very annoying and i can't wait to either fix this issue of get rid of the car.
