Old 10-11-2008, 05:09 AM   #10
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
Yes, if you are throttling in D and it does not change before 5500rpm it is starting to wear.
and your rev limiter on your 7mgte/7mge will be at a max of 6750 on the 6M crank which revs higher than the 7M crank unless of course you have an aftermarket ecu to which you have adjustable rpm limiter.
Pics of my build.
Do a diagnostic first!
